I had an unfortunate accident this past Sunday while playing at church. My strap came off and the guitar crashed. At 1st I thought everything was ok but when tearing down I realize the VDI cable wouldn't release from the jack. Later I began taking it apart and now see that the jack plate is damaged beyond repair.
So does anyone know where I can find a replacement? I've been scouring the internet but not having much luck.  Does anyone know if this part is interchangeable with another model perhaps?  I've seen a jack plate for a JTV-59 and the 69 and they look like they might match up in size. Does anyone have either one of these and let me know what the dimension are (length x width) ? Mine (the 89) is 3.25" x 1.25"
Thanks for any help you have!
Full Compass Systems is the only US parts supplier: www.fullcompass.com
One note is that they seem to stock very little and have to special order almost everything from Line6.  So, expect delays.
Thanks so much for the reply.  Yes, i have already checked there and I find 3 of the jack plate assemblies, 1 for a JTV59, 1 for a JTV69 and 1 for a Variax Bass but nothing for a JTV-89. The one for either the 59 or 69 look like they might work but I can't seem to find any confirmation if that is true or not.
Full Compass shows one for the JTV-59 and JTV-69, but none for the JTV-89.
You may have to special request the 89 jack plate.
The connectors may be the same, but the curvature of the plates and cable lengths
are not the same. I've worked on hundreds of JTV's,... it will make a difference in regards
to fit and function. Make sure you get the correct one from them,... 50-04-0079-2.
It will make a difference.
