Impulse Response -18db?
STPLE
Total stupid question - just trying to understand the Helix.  If this has already been addressed I'm sorry.  I've been looking.
Why are the third party IRs default set to -18.0db??  I usually end up leaving them at about -9 or -7db but for no good reason.  I'd like to know more about it if possible.
I appreciate it.
Gotcha.  So -14db is basically getting back it down from line level for Helix in a preset - right?  Any advice on bumping up the level??  Or is it usually best to leave it (avoid clipping, etc.)?  I know ultimately use your ears but just trying to understand it a bit better.
thanks!!
I think it depends on the IR as well. I made some from Mama Bear that end up needing to be between -6 and 0db. They're normalized, but I suspect that some of the stuff that's out there is more compressed and therefore needs the lower level.
Thanks guys.  Boy the more I learn the less I realize I know.  Now that I kinda understand the concept I won't be so quick to turn those up and make them louder right off the bat.  Thank again.
