Helix Rack Tap Tempo Oddity
inveigle
Even after setting the "Tap Tempo LED" to Off in the global settings it will come back on if I use the Tap Tempo button on the Helix Rack rather than the floor controller. When I go into the global setting it says it is off even though it is blinking. I have to turn it from Off to On and back to Off to get it to stop blinking. I did a factory reset and reinstalled 2.0 but the problem persists. Can anyone else try this to see if have the same results please?
Support ticket opened.
Confirmed just now - exactly as above.
... actually, using the Helix Control's tap tempo footswitch turned it back on for me also - as above, the Global settings still shows it as off.
Thank you MonkeyXT. This troubleshooting should help Line 6 sort this out quickly.
Reply from Line 6
___________________________________________________________________________
Line 6 Support replied to your support request with the following:
Thanks for the input.  This is a indeed a bug.  It has been logged and will be fixed int he next update.
Thanks,
Line 6 Support
