I think there is a bug in the editor in vintage digital delay
Paolo_Maina
I haven't played with it yet. Is the mix a wet/dry mix? I have to mess with it later. I will see if it's the same here (most likely is).
The bug is in the editor. The Mix parameter isn't showing up in the editor when you select the mono version of the Vintage Delay model. It actually exists on the Helix itself. And, yes, the mix parameter controls the wet/dry mix.
