victorloher Posted July 16, 2016 Share Posted July 16, 2016 Is there any way to set a Global Gate which will apply to all patches? Thanks for you help. Vic Quote Link to comment Share on other sites More sharing options...
MonkeyXT Posted July 17, 2016 Share Posted July 17, 2016 No, not in the current scheme of things. You'll be tasked with adding it manually - but I'll take this moment to remind you that, if you're short on blocks available, or just want to use what's already there, there's a gate at the input ready to activate and use. Quote Link to comment Share on other sites More sharing options...
jpdennis Posted July 17, 2016 Share Posted July 17, 2016 As far as the gate I use the feature in an input block that I just copy to each and every preset I want that same setting to be use in. It is quite effective for me. YMMV I have even created a "my favorites 1 & 2" for blocks I want to have to copy and paste as needed in other presets as I build more. Dennis Quote Link to comment Share on other sites More sharing options...
jorisgriffioen Posted July 17, 2016 Share Posted July 17, 2016 The most effective would be a sidechained gate that senses on the input but actually gates after all the gain. Kinda like the NS2 but then actually good. ;) The beta software on the GSP added that and it's heaven, you can build insane patches (DS1 on full gain into an SLO for instance) and it doesn't give a beep unless you want it to. :) Quote Link to comment Share on other sites More sharing options...
victorloher Posted July 20, 2016 Author Share Posted July 20, 2016 Thanks all for the responses. I am going to give the ideas a try. Quote Link to comment Share on other sites More sharing options...
ricksteruk Posted July 20, 2016 Share Posted July 20, 2016 The most effective would be a sidechained gate that senses on the input but actually gates after all the gain. Kinda like the NS2 but then actually good. ;) The beta software on the GSP added that and it's heaven, you can build insane patches (DS1 on full gain into an SLO for instance) and it doesn't give a beep unless you want it to. :) Yes that is definitey the way the gate should work. I was actually surprised when I added a gate after my amp block to find that it didn't do this already .. it makes the gate a lot less effective. Quote Link to comment Share on other sites More sharing options...
