autay622 10 Posted July 18, 2016 I want to get ride of a split and merge in my signal path and cannot figure out how to do so, either on my Helix or in the editor. Please help :) Quote Share this post Link to post Share on other sites
phil_m 4,522 Posted July 18, 2016 I want to get ride of a split and merge in my signal path and cannot figure out how to do so, either on my Helix or in the editor. Please help :) Just move or delete any blocks you have on the parallel path being served by the split and/or merge blocks, and the path and those blocks will go away. Quote Share this post Link to post Share on other sites
texasdave 6 Posted July 18, 2016 Just move any blocks you want to keep back to main path and delete any you don't. once the "B" path is empty it goes away. See page 16 Helix 2.0 manual (This section on paths is worth the read.) Removing Parallel Path BTo remove path B, simply clear any blocks on path B (lower) or move them all back up to path A (upper). Quote Share this post Link to post Share on other sites
texasdave 6 Posted July 18, 2016 yeah, what Phil said ;) Texasdave Quote Share this post Link to post Share on other sites
autay622 10 Posted July 18, 2016 Does not seem to be working for me... Quote Share this post Link to post Share on other sites
silverhead 8,809 Posted July 18, 2016 Can you not select (click on) the split/merge blocks and delete them? Quote Share this post Link to post Share on other sites
texasdave 6 Posted July 18, 2016 not using editor right now, but helix standalone I can't duplicate what you have. As mentioned above, if you move to the split block does it give you the option to delete that block when you press "Action?" If you disconnect from computer and load the patch are the results the same? Maybe add a block in there and delete it? You may have tried all that, but I just built a patch using the same general blocks you have and couldn't get mine to that state. Texasdave Quote Share this post Link to post Share on other sites
HonestOpinion 922 Posted July 19, 2016 Does not seem to be working for me... That is strange, I can't get my Editor to do that. If I delete or move all the blocks on a path the split/merge blocks and the line representing the second path go away automatically. What OS are you on? I am wondering if you might want to uninstall and then reinstall the 2.0 Helix Editor app software. If this is is still happening on your Helix as well as the Editor while the Editor is not connected, I would back up my IRs and presets and reinstall the firmware update and do the global reset as well. Can you reproduce this behavior on any preset or just select presets? Quote Share this post Link to post Share on other sites
duncann 758 Posted July 19, 2016 Someone else was also having this problem: http://line6.com/support/topic/21055-helix-too-many-paths-clearing-them/ Must be some sort of rare bug. Or easter egg? Quote Share this post Link to post Share on other sites
autay622 10 Posted July 19, 2016 I did an editor re-install and a firmware update/reset.... I was still able to recreate this bug... Then I disconnected the helix from the computer, and deleted the reverb block post split... still no change Then I just moved the cab/amp block to the second path and back... and the second path suddenly went away! Doesn't make any sense to me but there you go! Quote Share this post Link to post Share on other sites
HonestOpinion 922 Posted July 19, 2016 I did an editor re-install and a firmware update/reset.... I was still able to recreate this bug... Then I disconnected the helix from the computer, and deleted the reverb block post split... still no change Then I just moved the cab/amp block to the second path and back... and the second path suddenly went away! Doesn't make any sense to me but there you go! Did you do an uninstall of the Line6 components first before doing a reinstall, if not that may be worth a try? Also, if you have any third party anti-virus or firewall apps you may also want to try momentarily suspending them (especially during the install process) as well as the, pardon me for suggesting it, obvious step of making sure nothing else is running during install and testing to see if the same behavior persists. And of course, make sure to do the 9&10 global reset after your firmware upgrade. I would also make sure you download a fresh copy of the Helix App in case your's is corrupted. If you are using IE 11 make sure to heed the Line6 install warning regarding corrupton of the download by Smartscreen in this version of IE. Also, does this happen on any presets you delete a path on? This is strange behavior, hope someone can help you sort it out. Quote Share this post Link to post Share on other sites
