Giorgos02 Posted July 21, 2016 Share Posted July 21, 2016 Hey guys, I want to try using my Pod HD500X with some pedals for a couple of weeks so I can test its' effects. So I am searching for a single unit that will be able to supply with power my Pod HD and 2-3 more pedals. And at the same time it will have isolated outputs so that I won't get any ground loop noise any more. I need to find something that it is not too expensive, so I was looking at this: http://www.t-rex-effects.com/fueltank-classic/ But I am not sure if it will work for my Pod HD What kind of power supply does the Pod HD500X needs to work???? (I am not familiar with the terms, so excuse my mistakes.) Thanks in advance! Quote Link to comment Share on other sites More sharing options...
cclement Posted July 22, 2016 Share Posted July 22, 2016 You'll need a power supply that puts out 9V DC, 3 amps (3000ma). The HD500X pulls a great deal more that your standard flanger pedal (typically 500ma)... so finding one that is up to the challenge AND can handle pedals on top might be tough. Quote Link to comment Share on other sites More sharing options...
brue58ski Posted July 25, 2016 Share Posted July 25, 2016 No that won't work. As cclement said, not enough amps. Also the specs for the DC plug that are on the Line 6 website are WRONG!!!! I spent $20 finding this out the hard way. Here's what I posted in another thread. WARNING:WARNING. I know according to the specs the "hole" on the connector is 2.1mm but this is WRONG!!!. 2.1mm is too small. I wasted $20 finding this out. The correct measurment is 2.5mm not 2.1mm. I was trying to get an elbow adapter for the 500 and the 2.1 didn't work. The specific measurements were. 5.5 X 2.5. This is what I got. BiXPower LC53 Right Angle Connector Converter for 5.5 x 2.5mm DC Power Connector This size worked. I don't know why their measurements are so off. Quote Link to comment Share on other sites More sharing options...
FlyingSquirrel Posted July 25, 2016 Share Posted July 25, 2016 This thread may provide some insight as I had the same question a couple of months back. http://line6.com/support/topic/19997-anybody-using-any-one-spot-products-with-their-hd500x/page-1?do=findComment&comment=150788 Quote Link to comment Share on other sites More sharing options...
FlyingSquirrel Posted July 25, 2016 Share Posted July 25, 2016 And the more comprehensive version: http://line6.com/support/topic/20373-show-your-boards-stereo-setup/?p=153613 Quote Link to comment Share on other sites More sharing options...
Giorgos02 Posted July 28, 2016 Author Share Posted July 28, 2016 You'll need a power supply that puts out 9V DC, 3 amps (3000ma). The HD500X pulls a great deal more that your standard flanger pedal (typically 500ma)... so finding one that is up to the challenge AND can handle pedals on top might be tough. No that won't work. As cclement said, not enough amps. Also the specs for the DC plug that are on the Line 6 website are WRONG!!!! I spent $20 finding this out the hard way. Here's what I posted in another thread. WARNING:WARNING. I know according to the specs the "hole" on the connector is 2.1mm but this is WRONG!!!. 2.1mm is too small. I wasted $20 finding this out. The correct measurment is 2.5mm not 2.1mm. I was trying to get an elbow adapter for the 500 and the 2.1 didn't work. The specific measurements were. 5.5 X 2.5. This is what I got. BiXPower LC53 Right Angle Connector Converter for 5.5 x 2.5mm DC Power Connector This size worked. I don't know why their measurements are so off. This thread may provide some insight as I had the same question a couple of months back. http://line6.com/support/topic/19997-anybody-using-any-one-spot-products-with-their-hd500x/page-1?do=findComment&comment=150788 Thank you everyone for your responses! Can any of you suggest a unit that would work with the Pod HD500X and 2-3 more pedals? Quote Link to comment Share on other sites More sharing options...
FlyingSquirrel Posted July 28, 2016 Share Posted July 28, 2016 Well, the ONE Spot and its associated adapters has been working for me using the HD500X and some additional pedals. I got the polarity inverter based on the feedback/counsel from TruTone, and it's a perfect fit.Not sure about any right angle adapters though. Quote Link to comment Share on other sites More sharing options...
