Sign in to follow this
esarlag
output patches' level how to harmonize?
Hi
i use audacity (USB into PC) to set the "same" output level for my patches, by playing a chord (rythm) or a string note (solo) and manage to get the same signal on the bargraph (dB)
Is there a better issue to do this?
Personally I just use a sound meter app on my phone.  I play through my normal rig setup and normalize all the patches to about 80db.  Works fine for me and just takes a minute to check and adjust things.  I lay the phone on the desk a couple of feet away from the speaker, turn it on and play guitar through the patch, and I can see the levels.
Your USB signal level is different than your volume output, so I'm not sure which one you're trying to measure.
I first played a patch through a mixer console, and adjusted the patch level to be correct. Then, I used that patch at home, connected to my daw, and I measured the level. That was the reference for the other presets to adjust.
Which app are you using?
