Amplify 150 and Pod XWT Live?
harleymon
I have a Pod XT Live Pedal, Amplify 150 as well as the Sonic Port VX.
 Does anyone know if the POD XT Live is compatible with the Amplifi 150? Am I able to use it along with the Amplifi 150 and run the tone into the Amplifi 150 ( VIA Instrument patch Cable). Then can I edit the Tone through the Amplifi's iPad  "Edit" program?
Depends upon what you mean by "compatible."  You may use it as you would any effect pedal in-line between your guitar and the amp, but it will be a mono signal into the Amplifi. Anything you do from the Amplifi app will then affect your input signal as designed. Not sure what the benefit would be to run it that way, but trial & error will provide that answer for you. If you're looking for sound changes via pedal, I would consider purchase of a compatible pedal and just set up your chosen tones into the  banks from within the app. Prior to doing so, I would backup each "stock" tone to "my tones" so you can overwrite any of those factory tones with your custom mods in any order you want; the backups give you access to those factory tones for recall any time you may want without having to flash the firmware in order to restore factory presets. Unfortunately, you have to do it one at a time by first choosing each tone, then saving to "my tones" one by one. It's time consuming, but hopefully you'll get away with doing only one time.
