Sign in to follow this
vampysol
Windows 10 Last Version & Drivers Crash DAW's
Hello friends.
Today Install the latest version of Windows 10 before another older version of windows I did not happen this:
when Studio One or Reaper looks for the ASIO driver does not detect it, and crash DAW! only occurs with Windows 10 latest version. (Windows 10 v1607 x64bits) in MAC OS nothing like this happens,, everything normal.
I reformatted , I installed again. and the problem does not go away someone happened this problem? I reset my Pod HD Pro X , installed drivers again bla bla bla ... :unsure:
regards!
You need to download the drivers from Line6 (or download Line6 Monkey).
I had a similar issue when I upgraded to Win 10, and it didn't recognise my HD. Installed the drivers, then plugged the HD in, works fine.
Just to note, If Windows 10 Updates to the Anniversary update- You will need to Re-install drivers as well!
Hello friends.
I formatted the PC again, and the problem continues.
I tried it on another PC, and not the driver problem is hardware POD HD!
I used different cables, different ports 2.0 and 3.0.
and only the ASIO driver works with Ableton Live but not always :(
this will have solution? I am very sad
Hello friends.
Same kind of problem here...
I can use it as a sound card with the Windows drivers but not the ASIO in Presonus Studio one 3.3.
Everything is OK in system...
I reinstall all line6 software but nothing changes.
Best
Hi. I had the same problem and I think I finaly got it to work out! Check out my thread:
"Pod HD500X causing crash in Reaper"
Create an account
Register a new account
Sign in
Sign In Now
