MusicGeek
Auto power off Relay G30?
Hi. I've just purchased a Relay G30. First impression it's great: large signal coverage, clean sound, and no latency.
I have a question: has the G30 an auto power off feature when no in use? Must I switch the unit off manually always?
G30 needs to be turned off when you are not using it, or you will drain the batteries.  for future use - the G70/75 has a sensor that will put it to sleep after it has nothing happening for a bit, and the G10 will go to sleep when not being used either.  hope this helps!
