anthony_jardine
Can the Firehawk turn on and off external stompboxes
Just wondering, as I ideally want to run an additional pedal board along side my Firehawk fx with additional stompboxes but still be able to turn all effects off via the Firehawk when changing presets. If this is possible could someone tell me how I can achieve this? Thanks so much
I don't know of a way to turn off the pedals but I think you could drop the whole pedal board by turning off the fx loop
Ah that's interesting... so I could switch off the entire board when switching presets.. only thing is when I try to connect it via the FX loop input on back of the board I don't get anytbing coming through the amp... could you tell me how I'd hook this up correctly? Thanks!
Make sure the fx loop block in the software is "on".  It should be connected guitar->firehawk->pedal board->firehawk->amp in the simplest scenario.
This is correct, and the loop can programmed on/off or volume up/down for each patch.
