tochiro Posted September 8, 2016 Share Posted September 8, 2016 Hi, Sometimes the receiver has no halo at all when plugged in and the transmitter is by its side and charged. Sometimes in the same situation the receiver has a pulsating halo. Is it normal? Cheers Quote Link to comment Share on other sites More sharing options...
MusicLaw Posted September 8, 2016 Share Posted September 8, 2016 No! Normally the base will display a slow blinking white halo when the power is on and the transmitter is not inserted into the base. Check to make sure the USB cable connected to the USB jack at the rear of the base is securely plugged into the jack, and that the AC transformer is not using a switched off AC outlet. Quote Link to comment Share on other sites More sharing options...
