Pitch Shift Help
bshaw92
I usually setup a pitch shift to tune down a half step. It is not working the same in the simple pitch. I have a "warbly" sound and no other effects are on. Has anyone had success in this area?
I pulled this out of a similar thread from a little while back.
See if it is what you're trying to achieve. It uses a "Pitch Whammy" block, not the simple pitch.
Here's a link to a tone I made that already has an "Eb Drop" switch for you to play around with.
http://line6.com/cus...e/tone/2031305/
Have fun!
PLEASE NOTE: A lot of users have complained that the upgrade to FW2.0 has screwed up the pitch shifting quality. Digital Igloo states that Line 6 are aware and a patch to revert the shifter algorithms will be made available.
I'm pretty certain the 201 update reverted to the earlier pitch algorithm. Not super hi-fi, but many people found it better than what was in 2.0.
Yes. Certain chords produced some really funky sounds in 2.0. Other than that, I found the tracking better in 2.0. Prior to that, and in 2.1, it's seems really flaky, to the point where I wouldn't even consider using the pitch blocks for any kind of extreme detuning, unless the track being detuned is somewhat shrouded with other tracks.
