a1terrier 37 Posted September 12, 2016 Hi all Seem to remember a post on how to connect a pod 2 to SJam using MP3 input on amp but can't seem to find the post Can anyone suggest the right way Thanks Quote Share this post Link to post Share on other sites
fflbrgst 1,852 Posted September 13, 2016 Is the Pod output stereo or mono? Just a matter of some simple adapters/cables. Quote Share this post Link to post Share on other sites
a1terrier 37 Posted September 14, 2016 Hi Thanks for reply It's got a left and right output but I seem to remember a way of linking to amp using phone socket on pod Maybe I'm mistaken and I just went from left on pod output into MP3 socket on SJam Quote Share this post Link to post Share on other sites
Brazzy 440 Posted September 14, 2016 Maybe you could clarify exactly what you want to do, I'm a bit confused. Quote Share this post Link to post Share on other sites
a1terrier 37 Posted September 14, 2016 Hi I'm trying to use the pod 2 through the Spider jam but bypassing the amp bit so I'm just using the speaker in the jam 1 Quote Share this post Link to post Share on other sites
fflbrgst 1,852 Posted September 15, 2016 If you are using any stereo patch on the Pod, you would want to use the left & right outputs. You could also use the headphone stereo output, of course. 1 Quote Share this post Link to post Share on other sites
Brazzy 440 Posted September 15, 2016 Hi I'm trying to use the pod 2 through the Spider jam but bypassing the amp bit so I'm just using the speaker in the jam The pod can sound pretty good if you just run the 1/4" L mono out into the Aux in on the SJ. I do this all the time but I've got the SJ's Aux in Tone stack/Reverb and Delay/ Compressor settings set to the way I like. You could also use an insert cable like this. Insert Cable Quote Share this post Link to post Share on other sites
a1terrier 37 Posted September 15, 2016 Thanks for reply Brazzy Does that mean using left and right output on pod? Quote Share this post Link to post Share on other sites
Brazzy 440 Posted September 15, 2016 Thanks for reply Brazzy Does that mean using left and right output on pod? Yes it does. Insert cables are handy have around. I have one with 1/4" to 1/4" and use it with my HD500 to run pedals between the FX loop send and return on it. Quote Share this post Link to post Share on other sites
a1terrier 37 Posted September 16, 2016 Thanks again Brazzy-will def give that a try Quote Share this post Link to post Share on other sites
a1terrier 37 Posted September 16, 2016 Hi Going to try left ouput into aux tonight, would there be a noticeable difference in sound between this and using the twin 1/4"? Thanks Quote Share this post Link to post Share on other sites
Brazzy 440 Posted September 16, 2016 Hi Going to try left ouput into aux tonight, would there be a noticeable difference in sound between this and using the twin 1/4"? Thanks I'm not sure about the Pod 2 'cause I never had one. I don't think your have too much problem. Remember the SJ has an input setting for the CD/mp3 jack and Aux input so keep that in mind if you haven't. Tap the "input level" button twice and you'll see adjustments can be made to the "mic input", "aux input" and "cd" input. I usually set these with the Master Volume knob maxed. When I use my HD500 with the SJ I have the SJ's master maxed, the input setting at "0" and I start with the Pod's Master below 50% and adjust up as needed. Of course your patch settings matter too but I think If you start out with a basic patch it should sound good. I'm just very familiar with the Pod 2. I got this from the manual for the Pod 2 http://line6.com/data/6/0a060b316ac34f0593b343dc6/application/pdf/POD%202.0%20Pilot's%20Guide%20-%20English%20(%20Rev%20B%20).pdf Left & Right Output – These are balanced 1/4-inch TRS connectors, and ready to rock with pro +4 dBu balanced equipment. They will also work happily with unbalanced - 10 dBV equipment and standard guitar cables. If you are running POD mono, use the Left output. A.I.R. Mode – If you’re plugging your POD into a guitar amplifier to use POD as a “front end†to change the amp’s tone, flip the A.I.R. Mode switch to AMP, and set your amp for a clean tone. This defeats the speaker-microphone-room tone simulation of the A.I.R. processing. If you’re using POD in almost any other setup (plugging direct into a mixer, recorder, PA, power amplifier, etc.) you want the DIRECT position of this A.I.R. switch. ​ Output Level – Controls the overall output level of POD. Also sets the headphone level. This setting is not saved when you store settings into one of the POD’s memory locations. Changing the Output Level does not change your tone. So you can get the tone you want at any volume level. Quote Share this post Link to post Share on other sites
a1terrier 37 Posted September 19, 2016 Hi Tried left output into Aux but no sound. Checked levels (I think) but nothing Quote Share this post Link to post Share on other sites
Brazzy 440 Posted September 19, 2016 Hi Tried left output into Aux but no sound. Checked levels (I think) but nothing No sound? Hmmmm. The only thing I can think of is that the AUX input isn't set correctly. Press on the "input settings" button twice and you will see 3 available settings. Use the wheel or the nav button to select the Aux and then use the wheel to adjust it's level. I'm usually always at +0 db which is in the middle of it's range. You can just plug your guitar into the AUX input to see if it's working that way too. Quote Share this post Link to post Share on other sites
a1terrier 37 Posted September 19, 2016 Thanks Brazzy Tried guitar straight into Aux but nothing, also tried just using my mp3 player into mp3 socket and again nothing. Doesn't sound good, do you think a factory reset would help? Amp is eight years old maybe its starting to die on me. Quote Share this post Link to post Share on other sites
Brazzy 440 Posted September 19, 2016 Thanks Brazzy Tried guitar straight into Aux but nothing, also tried just using my mp3 player into mp3 socket and again nothing. Doesn't sound good, do you think a factory reset would help? Amp is eight years old maybe its starting to die on me. Mine's the same age and still working good. Some years ago I had to install the latest firmware 'cause the drums wouldn't play. Maybe you should try the reset and if that don't work reinstall the firmware. I had a bug recently where when I plugged the guitar into the aux input when I changed the amp models they were affecting the Aux input. Very weird and I think I toggled the "mic recording/aux recording" button a couple of times and then set it to "Mic/Aux" then turned the amp off and on to get back to normal. So given the experiences I've had it can be buggy. I don't know why. I've been lucky for a while now. I do understand that ribbon cable connections inside the amp can come loose or get tarnished over time and need to be cleaned or just pulled off and pushed back on a few times to fix. I suppose excessive vibration can loosen them too. Quote Share this post Link to post Share on other sites
a1terrier 37 Posted September 19, 2016 Thanks again for reply Will try reset and then re-install. Might have a look in the back as well to see if there is anything obviously loose Quote Share this post Link to post Share on other sites
a1terrier 37 Posted September 19, 2016 Hey Brazzy. Reset worked fine, also works from headphone on Pod to mp3 on SJam again!! Must have been a glitch on that panels connectors, might last me another eight years!!!! Thanks again for your help. 1 Quote Share this post Link to post Share on other sites
Brazzy 440 Posted September 19, 2016 Hey Brazzy. Reset worked fine, also works from headphone on Pod to mp3 on SJam again!! Must have been a glitch on that panels connectors, might last me another eight years!!!! Thanks again for your help. You're Welcome. Cool, glad to hear that. If I have an issue in the future I'll try the reset. How is the reset done? lol Quote Share this post Link to post Share on other sites
Brazzy 440 Posted September 19, 2016 Don't forget the Aux input has it's own EQ, Reverb, Delay and Comp in the settings part. Quote Share this post Link to post Share on other sites
a1terrier 37 Posted September 20, 2016 Thanks for info Turn off SJam then hold tone/settings whilst turning on, keep pressed down for about 10 seconds. 1 Quote Share this post Link to post Share on other sites
Brazzy 440 Posted September 20, 2016 Thanks for info Turn off SJam then hold tone/settings whilst turning on, keep pressed down for about 10 seconds. No problem and Thanks for the reset reminder. Quote Share this post Link to post Share on other sites
a1terrier 37 Posted September 20, 2016 Hi Brazzy Just a quick question Would the insert cable using both left and right outputs on my pod sound better/different to just using the left output Thanks Quote Share this post Link to post Share on other sites
Brazzy 440 Posted September 20, 2016 Hi Brazzy Just a quick question Would the insert cable using both left and right outputs on my pod sound better/different to just using the left output Thanks I'm not real sure what the difference would be but I would think that since your running the pod stereo into the SJ which is ultimately mono your not going to get the full benefit but maybe your tone will sound a little thicker maybe. I would say your going to get pretty good tone just running the 1/4" Left Analog out into the Aux input. I do this all the time for a quick practice session with my HD500 or X3 Pro. Sometimes I'll take the output of the SJ out with a stereo insert cable and run that into the FX Return of my HD500 and it sounds pretty good when I digitally record monitoring with headphones. I also put my drummer pedal (Beat Buddy) in stereo the same way. Quote Share this post Link to post Share on other sites
a1terrier 37 Posted September 20, 2016 Thanks again for reply Guess I've got enough tone options to be going on with. Quote Share this post Link to post Share on other sites
Brazzy 440 Posted September 20, 2016 Thanks again for reply Guess I've got enough tone options to be going on with. Yepper, Have you ever tried your pod in stereo? Do you have 2 amps or other powered speakers? Quote Share this post Link to post Share on other sites
a1terrier 37 Posted September 20, 2016 No I haven't tried that I've got the SJam and a small 5 watt tube amp I built from a kit. Would that work? Got to say that reset has made a difference. SJam was sounding a bit flubby but seems to sound a lot more alive now. Maybe it's just me but seems a lot better. Quote Share this post Link to post Share on other sites
Brazzy 440 Posted September 20, 2016 No I haven't tried that I've got the SJam and a small 5 watt tube amp I built from a kit. Would that work? Got to say that reset has made a difference. SJam was sounding a bit flubby but seems to sound a lot more alive now. Maybe it's just me but seems a lot better. Cool glad the reset cleaned things up. Sure you could use your kit amp. It might not sound the way you want it to but the only way to find out is to try it. I've used my Jet City Picovalve which is 5 watt with my Spider Jam. I've also used my Spider Jam & DT50HD in stereo. Both ways sounded pretty good for me. If your 5 watt amp has an fx return plug your pods 1/4" output to it, if not plug in the front of your 5 watter and try to EQ it sound as good as you can get it. Quote Share this post Link to post Share on other sites
