Graven23 Posted September 15, 2016 Share Posted September 15, 2016 Hi! i bought a pod xt live second hand recently, but it has a problem with the pedal that is not working at all, when the wah is turned on, on the line 6 edit the knobs goes "crazy" it begins to chance the wah values from 24% to 100%, what can i do? Quote Link to comment Share on other sites More sharing options...
BillBee Posted September 15, 2016 Share Posted September 15, 2016 Just a guess - but there is a ribbon cable that connects the mainboard to the exp pedal sub-board (IIRC) it might have come loose and needs to be seated. Its been a bit since I had one apart. Quote Link to comment Share on other sites More sharing options...
Tinyfireball Posted September 15, 2016 Share Posted September 15, 2016 H​I Gay! First make sure the pedal calibrated properly- you can do this by powering up with the"Bank Up" stomp switch held. This puts the unit into a special pedal calibration test mode.Press the "AMP ON\OFF" stomp switch to reset the calibration. Move the pedal to the heel position.Move the pedal to the toe position and depress the pedal toe switch.Move the pedal back to the heel position. When in the heel position now the "7MAPPEDxxx" numberon the LCD should read 0.Move the pedal back to the toe down position (you do not have to depressthe toe switch )the"7MAPPEDxxx" number should read 127.You should also see this number sweep from0 to 127 as the pedal is moved from heel down to toe down. Turn off the pedal , turn on and checkpedal. Quote Link to comment Share on other sites More sharing options...
HelixMan Posted November 24, 2016 Share Posted November 24, 2016 Thanks for the post - just picked up a used XT Live and had the same issue. Wah only went up to 36%. It's working correctly now - BUT...I can't get the volume pedal to respond / read. I set the config to both wah / volume on the onboard pedal 1 and tweak pedal 2. The wah works and when I switch to volume nothing - I have it turned on. Any help - thanks! Quote Link to comment Share on other sites More sharing options...
