Sonic Port VA and iOS 10
gk001
Hi All
For info, if anyone's contemplating upgrading
Both my iPad Air & iPhone 5s are working fine with Sonic Port VX and iOS 10
Tested with the following with no issues
Mobile POD
Garageband
Cubasis
Polytune
4Track
Sonoma Guitar Tone
Music Memos
Skype
Will test with iPhone 7 and update as soon as it arrives...
  • 3 weeks later...
Hi!
I just bought my Sonic Port VX, and as soon I got home I've plugged it in my iPhone 6s with iOS 10.0.2, and it just didn't work!!!... The iPhone couldn't even find the hardware when I've opened Mobile POD app!!! On my MacBook it seems to work. But I bought it to use with the iPhone primarily and can't make it work!!! Does anyone can help me? Anyone with a solution? (I'm sorry for my rough english)
  • 1 month later...
  • 4 weeks later...
My 2nd unit Sonicport VX (purchasing via Line6's refurb program) works fine with IOS 10.2 on an iPhone SE.
That being said, the 1st unit I received actually was pretty much the same thing @Bipai described - was okay working via USB, but the Lightning port (or 30-pin, because I also tested it with an older iPod Touch and iPad 2) was completely non-functional.
In basic testing, I noticed if you are just supplying USB power to the Sonicport without connecting to either an iPhone, nor an actual PC/Mac, the unit won't show any signs of working (you can plug in a headset, but you won't hear anything.)
Until it is recognized as an ASIO device on a PC, it will not enable even the direct-monitoring switch.
Or if you then plug it into an Apple device (Lightning or 30-pin) with a compatible App running (important, because if you aren't actually running a compatible App while trying to use the Sonicport, it will similarly appear completely dead. (and per my prior finding, if you try to connect the Lightning AND the USB simultaneously, the USB side will be disabled for playback/recording (meaning the PC/Mac will not detect the device, and won't enable it until you disconnect the Apple device.)
Make sure you at least download and run the Line6 Mobile POD (you don't have to pay for the App - leave it in Trial Mode.) After a few minutes (took me about 5) of being connected to the Sonicport, the Mobile POD App will unlock itself and all the preset tones should unlock - but it doesn't happen instantly upon the first plug-in.  Before the App fully unlocked, my Sonicport initially appeared non-responsive on the Apple device, as well. Then after a minute or two, I saw the device show up in the Settings screen of the App.  And a few more minutes later, all of the lock icons disappeared (you may need to be connected to the Internet for this to happen, whether cellular or WiFi.)
