dhewer 10 Posted September 25, 2016 Hello group. how can i get a fatter sound out of the A30-TB? Using Bridge Humbucker. My chain has in it: [ with the settings so far] Noise Gate 50 50 ( only used when using signal coil) Boost Comp 61 33 56 3 o'clock 3 o'clock Tube Drive 53 50 47 10 o'clock 4o'clock AMP A30TB 56 69 100 65 50 100 27 AMP Parameters : standard no change CAB Parameters : only changed the Low cut to 9 o.clock Mixer A+B PAN Centre and +2dB Volume Pedal Reverb Hall 38 82 40 27 Thanks.. any help would be appreciated...... Quote Share this post Link to post Share on other sites
guilhordas 14 Posted September 25, 2016 Hello group. how can i get a fatter sound out of the A30-TB? Using Bridge Humbucker. My chain has in it: [ with the settings so far] Noise Gate 50 50 ( only used when using signal coil) Boost Comp 61 33 56 3 o'clock 3 o'clock Tube Drive 53 50 47 10 o'clock 4o'clock AMP A30TB 56 69 100 65 50 100 27 AMP Parameters : standard no change CAB Parameters : only changed the Low cut to 9 o.clock Mixer A+B PAN Centre and +2dB Volume Pedal Reverb Hall 38 82 40 27 Thanks.. any help would be appreciated...... changing the cab, use a marshakll 4x12 Quote Share this post Link to post Share on other sites
dhewer 10 Posted September 25, 2016 Thanks guilhordas , that sounds good......I added a Ping Pong Delay....BPM is 106 and the delay is 32 (dot).... Would you do this delay? or pick another one? hurghanico thanks man.....followed you adjustments...... Cheers Quote Share this post Link to post Share on other sites
guilhordas 14 Posted September 26, 2016 for me the best clean on pod is tweed b man brt with 4x12 highway and 421 dynamic, i think ac vox 30 very thin with the standard parameter Quote Share this post Link to post Share on other sites
guilhordas 14 Posted September 26, 2016 this is a very small audio example of what I get from the AC-30 model with its default cab miked with a 87 condenser mic https://soundcloud.com/hurghanico/ac-30-tone-test at the beginning starts a chords progression played with a LP Junior (P90 pickup) model, placed slightly on the left side.. then I added a solo/melody with a LP Standard placed slightly on the right side, there is a Tube Screamer, and after the amp an analog delay with mod, reverb.. to me it sounds quite fat and warm.. cab resonance is at zero.. amp standard controls are all at noon except Cut and Channel Volume at 100 and Presence at zero, (Treble could work good also up to about 60 to get a more bright and slightly nasal tone).. tube screamer: all defaults, except output at 50.. all default settings for the analog delay/mod and reverb very nice tone, but i think that vox(default parameters) direct to the pa sounds very different, at leats for me Quote Share this post Link to post Share on other sites
bjnette 149 Posted September 27, 2016 Recently I moved into a Unit and am using some Edirol Micro powered speakers after using Rokit G2 6' and the sound is noticeably thinner. I have treated the room with bass traps and broadband absorbers. and the bottom end is tubby. I have also used head phones as well lately ) and these are tubby sounding too. Hardly ever needed anything else past 10 years. Mentioning as it could be your monitoring? Quote Share this post Link to post Share on other sites
dhewer 10 Posted September 28, 2016 Here is my attempt Check it out http://line6.com/customtone/tone/2494767/ The POD is studio out L & R into a mixer with some good monitors in my studio. Note - on the Line 6 Audio-MIDI Devices in (Mac OS X 10) System Preferences in the Inputs & Recording tab, I am running about -3.0 dB, for the record sends. I guess that is a somewhat pad? Let me know what you think Quote Share this post Link to post Share on other sites
