egkor Posted September 25, 2016 Share Posted September 25, 2016 Hello, I've got a stock JTV-69 H/S/S, and a Fender Std (MIM) Strat H/S/S updated w/ Dimarzio Cruiser pickups mid & neck, and a Dimarzio AT-1 bridge pickup. I use a POD HD500 w/ L6Link to a DT-25. Using the regular 1/4" guitar input on the POD: When I simply switch from the Variax w/ Mags to the Fender Strat, there is a noticeable volume/output difference between the Variax and the Fender guitars. The Variax w/ Mags (no modelling) is lower in volume (in all 5 switch positions) than the Fender Strat. This was surprising. Is the JTV-69 H/S/S Variax, using Mags only, supposed to have a similar volume/output level to a H/S/S Fender Strat? I did notice that w/ the Variax I could raise the pickups 1/16"-to 1/8" closer to the strings, would that raise the volume/output a noticeable amount? I want to be able to switch between these 2 guitars using regular 1/4" guitar cable to the POD or amp. Any help/input appreciated. -Gary K Quote Link to comment Share on other sites More sharing options...
cruisinon2 Posted September 26, 2016 Share Posted September 26, 2016 When I simply switch from the Variax w/ Mags to the Fender Strat, there is a noticeable volume/output difference between the Variax and the Fender guitars. The Variax w/ Mags (no modelling) is lower in volume (in all 5 switch positions) than the Fender Strat. This was surprising. Not really. Unless you're dealing with identical sets of pickups, (and even then...) one set is bound to be hotter than the other. I rarely use the same patch with more than one guitar...hardly ever really. Quote Link to comment Share on other sites More sharing options...
egkor Posted September 26, 2016 Author Share Posted September 26, 2016 Hi @Guru, I see ... You did provide a solution: a set of patches for each axe. Thanks! -Gary K Quote Link to comment Share on other sites More sharing options...
captainnemo70 Posted September 27, 2016 Share Posted September 27, 2016 youve gpt different pic ups in both guitars, your guitar with the dimarzios in is a strat in name only. you either have to accept that the dimarzios are hotter and use that as a tonal difference, or run a copy set of the same patches throttled back, or alternatively have patches that get teh best from the variax, and patches that get the best from the "fender" and use them alternatively or option 3 , go into work bench and increase the output levels of the variax models so that they level match your other guitar Quote Link to comment Share on other sites More sharing options...
davidb7170 Posted September 28, 2016 Share Posted September 28, 2016 I changed out my 69S stock pu's with DiMarzio noiseless SC's mainly for the noiseless part, but they are somewhat hotter than stock SC's and hotter than the models, so I upped the volume on the models a bit to even them up. I also have a 59, and it's stock HB pickups are hotter than the noiseless SC's in my 69S. I copied my 69S presets in my Helix and in my HD500X before it, and reduced the input gain for the 59, so I can swap guitars. On the Helix, I put a gain block first and take it down -8 dB or so... Works fine. Dave Quote Link to comment Share on other sites More sharing options...
Smashcraaft Posted September 29, 2016 Share Posted September 29, 2016 I have modeled the sound + level of my main guitar PUs (hot EMG), using Variax Workbench. As result I can switch guitars when ever I like. Got 95% there, which woks good for me. Quote Link to comment Share on other sites More sharing options...
