mikewosoft Posted October 1, 2016 Share Posted October 1, 2016 I don't need the power or XLR out of the 120, however I'm thinking the 12" speaker might add to the sound. How close are these amps in sound based on the two speaker sizes? THanks! Quote Link to comment Share on other sites More sharing options...
fflbrgst Posted October 3, 2016 Share Posted October 3, 2016 Until the amps are actually released, its anyone's guess! Quote Link to comment Share on other sites More sharing options...
mikewosoft Posted October 14, 2016 Author Share Posted October 14, 2016 I picked up the Spider V 60 today to try it out. Worst experience I have had with a piece of gear in 30 years of playing. The presets sounded so bad I was loosing faith right off the bat, and then I played the drum rhythm tracks and they have no bottom on the 60 and then the front end display of the unit started flashing and the amp started cutting out. I switched from my Monster Power to the wall to see if that was the issue but it started doing the same thing. Unplugged re-plugged, same problem. Now it won't even stay on. Only highlight is that it sounds better when it's turned off. :D Quote Link to comment Share on other sites More sharing options...
LWV120 Posted November 5, 2016 Share Posted November 5, 2016 I just bought the v 120 and have no issues with the sound at all other than it is the weakest 120 watt amp I have ever had. A Fender mustang III will blow it out of the water without even breaking a sweat and it is only 100 watts.I thought I bought a 120 watt amp but on many many presets it just doesn't have the volume on clean settings. Quote Link to comment Share on other sites More sharing options...
dsetliff Posted November 9, 2016 Share Posted November 9, 2016 I thought the same thing with the presets until i turned up the channel volume knob then...wow! Sounds close to my HD150 half stack in volume. Quote Link to comment Share on other sites More sharing options...
wtrawick Posted November 10, 2016 Share Posted November 10, 2016 I have the 120 and have found it to have exactly the volume of output one would expect from such a powered amp. I wonder if you have a malfunction; unfortunately, it seems you wouldn't be alone with this. Quote Link to comment Share on other sites More sharing options...
cuch Posted November 18, 2016 Share Posted November 18, 2016 I have the Spider V 120 and the patches are set very low on the channel volume (like dsetliff said) out of the box. Once I started building my own patches and modifying the factory presets, the power is there for sure. Don't get discouraged LWV120. Also if you hook up an ipad and download the spider app, you can load up tons of patches that other users have created and uploaded to the cloud... just be careful though as some of these patches are super loud, so you turn the master volume down between loading patches. Quote Link to comment Share on other sites More sharing options...
