Expression Pedal connected to Helix/control to control midi device(s)
jcrhee
A quick setup, I have the Helix Rack and am using it with other devices like the Eventide H9. I know that via midi I can send a PC to the H9 from Helix via the Command Center. My question is if I have an expression pedal connected to the Helix, in my case it would be via the Helix Control, would I be able to use that expression pedal to send a CC via midi to the H9 so that I can adjust (as an example) the delay feedback of a particular H9 preset?
Thanks
Yep, you can do that. You just set up EXP1, 2 or 3 in the Command Center to send out the appropriate CC with whatever range of values you want. I'm doing this EXP2 and 3 to control some parameters on the Strymon Mobius and BigSky - works great!
