aLExnDEr72 Posted October 13, 2016 Share Posted October 13, 2016 When I connect my FVB Express MkII footboard to my spider IV 75 the tune led lights of the FVB spark once and the pedal does not work neither show any sign to be functionall (any led works). I tried with another CAT 5 cable but still have no response. Aditional to this, I can´t update the amp firmware because the program does not recognize the amp. FVB software is already updated. I guess malfunction started as I had both amp and fvb useless for a lapse (2 years). Other functions of the amp (buttons, knobs, eq, configurations, sound) appears to be working normally. My Question is if the damage could be at amp fvb port (not physical damage), or the pedal is damaged? I appreciate your help... :) Quote Link to comment Share on other sites More sharing options...
fflbrgst Posted October 13, 2016 Share Posted October 13, 2016 First thing to check is the jack pins in both the amp and pedal - where the Cat5 cable plugs in. If any are bent, it may cause the pedal not to work. Quote Link to comment Share on other sites More sharing options...
BillBee Posted October 13, 2016 Share Posted October 13, 2016 You can connect the MKII to the PC via usb - so try that to check it with the Control software. If the cable is good its one or the other. Quote Link to comment Share on other sites More sharing options...
