Replacing Magnetic Pickups
Could be the power mange circuit in the battery box on the guitar. Solder point or program glitch could send a "false battery low signal" to the main board,
which would keep it from turning on.
And don't use any of those cheap 3rd party batteries, use the correct Line 6 versions. Have had a number of problems with other batteries from other sources.
Have the JTV-59 checked out at your local Line 6 service center,....
https://line6.com/find/service_center/
  • 5 weeks later...
psarkissian
Thank you for your post.
I only have original products. It also does not work on the bench.
Grateful, but here in Brazil there is no authorized technical assistance?
When I go to the USA I will take to check. It is the best.
Sincerely, Cesar, Rio, Brazil
Agradeço a sua postagem. Só tenho produtos originais. Ela não funciona também na bancada. Grato, mas aqui no Brasil não há uma assistência técnica autorizada? Quando for aos EUA levarei para verificar. É o melhor.
Atenciosamente Cesar, Rio, Brasil
@psarkissian Any issue with putting a TV Jones Classic 4.8k humbucker into the bridge position of a JTV-69? I've had it in a standard strat and wanting to put it in my Variax because I really like the sound. I know you've recommending 6-8k but wondering if that is due to going north of that range more so than south of that range. Being like a 12K pickup may cause issues while something like a 5k may sound brighter but still be ok as far as the circuit is concerned. Thanks in advance!
