Equilibrium_606 8 Posted October 23, 2016 Hi Guys, I am battling to get Ableton Live 9 to change Snapshots on the Helix. I have my presets setup under Setlist 7 User 5 & want to change the different snapshots of a patch via Abelton. I setup the midi clip to change to the correct Setlist,Bank, presets & Velocity (0-7) to change in Ableton, but it keeps going to the Factory Setlist "18A Nothing Else Matters". I think I am over looking something, but can't figure it out. I am trying to achieve this is the session view.Any help in this matter will be greatly appreciated!!! Regards Jason Quote Share this post Link to post Share on other sites
duncann 758 Posted October 23, 2016 Not sure about the specifics of Ableton Live 9, but to change snapshots from the DAW, you'll need to send to Helix CC69 with a value of 0, 1, 2 ... or 7. That will change the snapshot within the currently selected preset. Quote Share this post Link to post Share on other sites
Equilibrium_606 8 Posted October 23, 2016 Hey there, Thanks for the reply. I managed to puzzle it out.......I was doing exactly what you mentioned above, but it was changing too bank 18A. The problem was on Ableton's Channel strip, I had to select "NO INPUT" & it sorted my problem out. Thanks for taking the time to reply! Regards Quote Share this post Link to post Share on other sites
Roberttheprole 25 Posted October 23, 2016 Hey there, Thanks for the reply. I managed to puzzle it out.......I was doing exactly what you mentioned above, but it was changing too bank 18A. The problem was on Ableton's Channel strip, I had to select "NO INPUT" & it sorted my problem out. Thanks for taking the time to reply! Regards Wow! Are you able to automate snapshot changes this way??? Quote Share this post Link to post Share on other sites
Equilibrium_606 8 Posted October 25, 2016 Wow! Are you able to automate snapshot changes this way??? Yes you can!!! Sorry for the late reply..... I attached some pictures too show you what I have done. See Photo 1 1) Create a Midi Track 2) Input setting (Select No Input) 3) Output to the corresponding MIDI channel on the Helix (In my case Channel 10) 4) Create a blank clip See Photo 2 5) Under Notes section turn off loop 6) Under Envelopes select Midi Control under the drop down 7) Select 69 - Hold Pedal 2 See Photo 3 *In that Scene, I have a Audio track of the song (Synth, Samples, etc) that plays like an arrangement (left to right). The MIDI clip i drag to the same time length as the audio. 8) Draw in the velocity (0-7 which is Snapshot 1 to Snapshot 8) in conjunction with the patch changes on the Audio track. for example: Clean @ bar 13, Drive @ bar 24, Phaser @ Bar 33, etc. Now all you do is launch the corresponding Scene & everything will change according to the track!! :) Hope this helps!!! 3 Quote Share this post Link to post Share on other sites
Roberttheprole 25 Posted October 26, 2016 Amazing! Thanks for sharing your methods! Your the man! Quote Share this post Link to post Share on other sites
Equilibrium_606 8 Posted October 26, 2016 Hey Robert, No problem what so ever!! Glad I could help! I am busy compiling some videos regarding the Helix, Ableton, my soft Synth setup & controller-less looping. As soon as I have it up, I will send you a link! 🙂 Quote Share this post Link to post Share on other sites
Roberttheprole 25 Posted October 27, 2016 Nice! Can't wait! Quote Share this post Link to post Share on other sites
d0stenning 62 Posted October 27, 2016 Just another reason why I ******LOVE****** Ableton - and of course - my HELIX :) Quote Share this post Link to post Share on other sites
toasterdude 57 Posted October 30, 2016 I am doing the same with Maschine. Still figuring out some tricks. Quote Share this post Link to post Share on other sites
Equilibrium_606 8 Posted November 2, 2016 Yeah guys, the wonders of technology.......I will hopefully have some form of video up within the next 2 weeks. Day job is a bit hectic at the moment & you guys probably know the drill....don't get enough time to focus on the things that matter. Thank you all once again for the interest in my post! :) Quote Share this post Link to post Share on other sites
Roberttheprole 25 Posted November 3, 2016 Yeah, hard to make time sometimes. No deadlines! Quote Share this post Link to post Share on other sites
Roberttheprole 25 Posted November 28, 2016 [quote name="Equilibrium_606" Hope this helps!!! Hey there Equilibrium, so I figured maybe you could help me with issue I'm having with helix into ableton latency. I can't seem to get it eliminated any clues? Quote Share this post Link to post Share on other sites
Equilibrium_606 8 Posted November 28, 2016 Hey there Equilibrium, so I figured maybe you could help me with issue I'm having with helix into ableton latency. I can't seem to get it eliminated any clues? Hey Robert, I can defiantly try :) First off I need some answers from you: a) PC or Mac? b Version of Ableton & 32bit or 64bit c) Processor & Ram I take that you are running the Helix as your input & output device in Ableton? If so what is the overall latency you are getting in milliseconds? I get about 25.5ms if I select the Helix. I do however use the Helix to run my samples, soft synth & my guitar. I don't have a guitar track in Ableton only a looper track that grabs audio from Helix USB 1&2 & loops it. I haven't had any issues regarding latency as yet & I am doing a lot of processing at the moment. If you can tell me more of what you are doing & how you are running the Helix in Ableton it will help a lot. Let me know so we can try & sort this out for you!!! Quote Share this post Link to post Share on other sites
Roberttheprole 25 Posted November 28, 2016 Running PC, with Intel core i7 6700k quad-core 4.0 GHz, and 32GB ram. Ableton live 9 standard, 64 bit. Just trying to record guitar through helix in ableton at the moment. If I can get that working, I'll try other stuff. So, I turn everything on, go to preferences, driver type ASIO, audio device ASIO Helix, ( only cause that's what the guy said to do when setting up an interface on the ableton video. I then set up the audio track to accept the helix signal, and I'm getting green signal in the meters, but nothing out of the speakers??? Then I change back to driver type back to MME/DirectX, and audio input device to digital audio interface (line 6 wave. and wow! now I'm getting signal out if the speakers, but lots of latency..... says output latency - 92.9 ms. Played around with the latency settings, with no luck. Quote Share this post Link to post Share on other sites
Roberttheprole 25 Posted November 28, 2016 And thanks big time, I'm so green here in this daw world! Quote Share this post Link to post Share on other sites
Ka5par 22 Posted November 28, 2016 Running PC, with Intel core i7 6700k quad-core 4.0 GHz, and 32GB ram. Ableton live 9 standard, 64 bit. Just trying to record guitar through helix in ableton at the moment. If I can get that working, I'll try other stuff. So, I turn everything on, go to preferences, driver type ASIO, audio device ASIO Helix, ( only cause that's what the guy said to do when setting up an interface on the ableton video. I then set up the audio track to accept the helix signal, and I'm getting green signal in the meters, but nothing out of the speakers??? Then I change back to driver type back to MME/DirectX, and audio input device to digital audio interface (line 6 wave. and wow! now I'm getting signal out if the speakers, but lots of latency..... says output latency - 92.9 ms. Played around with the latency settings, with no luck. Do you have the speakers (active) or amp and speakers (passive) connected to Helix? Definetly use the ASIO drivers, it's not possible to get workable latency otherwise. Quote Share this post Link to post Share on other sites
Roberttheprole 25 Posted November 28, 2016 I not even getting Audio out of my laptop speakers through ASIO Quote Share this post Link to post Share on other sites
Ka5par 22 Posted November 30, 2016 I not even getting Audio out of my laptop speakers through ASIO The speakers/amp needs to be connected to the Helix and you need to select Helix ASIO driver as the output device in the DAW. Maybe there's another way, but that's what I'd do. Quote Share this post Link to post Share on other sites
alexhelix87 0 Posted December 2, 2016 Hey guys, I just had a question for anyone here who is a midi guru... I want to run my helix with Ableton... but the way I wanna run it is that each patch triggers a song ( 1A=Song 1, 1B=Song 2, 1C=Song 3, etc) and then when I hit the mode button I have access to my effects with a few options for Ableton (Stop, Bridge, Forward etc )... can you guys let me know if I'm swinging for the stars or if this is actually achievable Quote Share this post Link to post Share on other sites
Equilibrium_606 8 Posted December 3, 2016 Hey guys, I just had a question for anyone here who is a midi guru... I want to run my helix with Ableton... but the way I wanna run it is that each patch triggers a song ( 1A=Song 1, 1B=Song 2, 1C=Song 3, etc) and then when I hit the mode button I have access to my effects with a few options for Ableton (Stop, Bridge, Forward etc )... can you guys let me know if I'm swinging for the stars or if this is actually achievable Hi Alex, I am pretty sure you will be able to do this. I will just have to sit down & mess around for you. The Effects side triggering (Stop, Bridge, Forward etc) will be possible with the Command Center. You will just map a CC to the corresponding effect you want to trigger in Ableton & map it accordingly. I will try to get a gap today, alternatively I will sit down on Monday (Off Day =D) & puzzle it out for you. The preset thing will most likely run with a dummy clip in Ableton Mapped to different scenes. As soon as I get it right I will send you a message! Quote Share this post Link to post Share on other sites
Roberttheprole 25 Posted December 3, 2016 I'm having trouble setting the midi channel in ableton, do I have to hook up the computer and helix with a midi cable somehow, or will the data travel through the dub cable? Quote Share this post Link to post Share on other sites
Roberttheprole 25 Posted December 3, 2016 When I select midi output my only option seems to be configuration, that takes me to the preferences menu under midi link, and not seeing an obvious way to set my desired midi channel Quote Share this post Link to post Share on other sites
Roberttheprole 25 Posted December 4, 2016 Ahh, got it. Midi channel selected, helix doesn't seem to be receiving the commands yet, onward! Quote Share this post Link to post Share on other sites
