saving from the cloud
persecutionsmith
The easiest way I found is to first select the Bank/Preset where you want to store your downloaded tone and then go to the cloud and download the tone. Once you have it in the editor and you have edited it the way you want it, just press and hold the knob under the display; this puts you in save mode, then you can press and hold again to save it or you can change the bank/preset or rename the tone before you press and hold to save it.
In the Spider Remote app, when you select a tone from the cloud, or "your tones" it will load into the amp temporarily.  When it does that You'll notice a "share" icon appear on the area where the name of the tone is located.  It's the one that looks like a box with an 'up arrow' coming from it.  Press that icon and it will give you the option to "Store on Spider V "  You choose which bank/preset spot you want to overwrite and then press done.
  • 1 month later...
I have no option to save to Spider v, im using the 30W is it maybe not a feature on that one?
You can save to the Spider V 30 both in the Spider Remote App and on the front of the amp. Hit the "share" icon in the app and then hit "Save to Spider V". To save on the front of the amp simply hold down on the scroll knob for 2 seconds, from there you can make any naming adjustments you want to your preset, and then hold the scroll know down another 2 seconds to save.
  • 9 months later...
