coosvandorsten Posted November 5, 2016 Share Posted November 5, 2016 Here is the situation; I do run the Helix into an Engl Invader. Use tree foot switches to activate the Amps' Bright, High Gain and Master Volume AB via midi CC toggle. Works fine. But when I activate one of each footswitches, let's say Hi Gain, and then go to another snapshot the amp stays in the same mode. The new snap shot has not an active Hi Gain footswitch. From there on the function of the assigned Hi Gain footswitch works in reverse. When the light is on, so activated Hi Gain function, the Hi Gain on the amp is off and vice versa. Why does the Midi CC toggle function not reset the value during snapshot changes? Is there a way around this? Quote Link to comment Share on other sites More sharing options...
jmp22684 Posted November 7, 2016 Share Posted November 7, 2016 Maybe post what you're trying to do in some images? Having difficulty understanding the exact circumstance. Also need to look up the type of midi messages your amp accepts. Personally I need to send PC messages. The first thing is to head over to the global settings and turn off the send pc messages. Then I set each snapshot up to send an instant messages. Example: Snapshot 1-4 respectively: Intro Prechorus Chorus Lead Amp channels Program Change: 0 = clean 1 = crunch 2 = OD1 3 = OD2 With the global pc off and these set as instant program changes everything works pretty well. I haven't goofed much with cc toggle on any amps yet as mine only accepts pc. Now... a PC toggle would be SWEET for those of us with these amps. Quote Link to comment Share on other sites More sharing options...
Anim8me2 Posted November 7, 2016 Share Posted November 7, 2016 Check out this video I just posted. It's for an H&K amp but the bit about assigning midi commands to snapshots might help.http://line6.com/support/topic/17611-using-helix-with-amps/?p=180823 Quote Link to comment Share on other sites More sharing options...
coosvandorsten Posted November 7, 2016 Author Share Posted November 7, 2016 Thanks for the feedback. It works now using instant commands with CC messages with snapshots. Safes also a few buttons. A pitty my first scenario does not function like I thought. I was used to it using the G system. Quote Link to comment Share on other sites More sharing options...
Anim8me2 Posted November 8, 2016 Share Posted November 8, 2016 Glad to help, I know it drove me nuts at first. Quote Link to comment Share on other sites More sharing options...
