musiclover7 Posted November 18, 2016 Share Posted November 18, 2016 This may seem like an elementary question to some, but I am perplexed. First, what I am trying to accomplish, is to free up an extra footswitch in a patch. The footswitch currently adjusts the feedback and the mix setting on my delay. I am trying to figure out how maybe use the expression pedal for this purpose, but I am hitting a snag. Seems like in order to switch expression pedals (already using it to engage wah on Exp1, I need to leave the pedal in its maximum position, which means there seems to be no way for me to switch on wah, without simultaneously maxing out my delay feedback setting. I guess the obvious answer is to just buy a separate exp pedal, but I am curious if anyone has figured out a way around this puzzle using just the vanilla helix. Quote Link to comment Share on other sites More sharing options...
phil_m Posted November 18, 2016 Share Posted November 18, 2016 Well, DI already let the cat out of the bag about this one over on another thread, but one thing that's being added in the next update is the ability to set whether the expression pedal is set to EXP1 or EXP2 per snapshot. So with this, you can have the pedal be set to whatever you want on a snapshot per snapshot basis, so you should be able to do what you want. The only caveat with this is that you'll need to have the EXP Position setting in the Global Settings menu set to Global or Per Preset (not Per Snapshot). So jut hold out until the next update, and you should be good to go. Quote Link to comment Share on other sites More sharing options...
hefonthefjords Posted November 18, 2016 Share Posted November 18, 2016 Edited because nonsense*phil_m - I don't think you understand what's being asked here.OP - There is no way I can see to do what you ask without having a second expression pedal connected in some form, either via midi or as dedicated EXP2 or EXP3. Bummer. Quote Link to comment Share on other sites More sharing options...
hefonthefjords Posted November 18, 2016 Share Posted November 18, 2016 Is there an option for EXP position as per snapshot already? I don't remember that being a thing.... Quote Link to comment Share on other sites More sharing options...
phil_m Posted November 18, 2016 Share Posted November 18, 2016 Edited because nonsense* phil_m - I don't think you understand what's being asked here. OP - There is no way I can see to do what you ask without having a second expression pedal connected in some form, either via midi or as dedicated EXP2 or EXP3. Bummer. No, I understand completely... Right now there's no way to do what he wants to do, but after the update, there will be - but it will take switching snapshots to do it. If that's not an acceptable solution, than, yes getting an external pedal is the only workaround. Quote Link to comment Share on other sites More sharing options...
phil_m Posted November 18, 2016 Share Posted November 18, 2016 Is there an option for EXP position as per snapshot already? I don't remember that being a thing.... Yep - under the Global Settings menu. Quote Link to comment Share on other sites More sharing options...
hefonthefjords Posted November 18, 2016 Share Posted November 18, 2016 AHHH, you're right. After the update it can be done via snapshot. Now it has to be done by extra expression pedal.I didn't know that per snapshot setting was there. New things to play with all the time! Quote Link to comment Share on other sites More sharing options...
