Sign in to follow this
bleepbot
Sonic Port lightning charging solution?
Very interested in finding a solution too.  I think the below item would work.  The headphones only/won't data sync are what most of them are.  It's not nearly as expensive as the irig powerbridge ($80).  Seems like a simple hack to route the 5 volt from a different source though....
If this does work I would expect that you would get noise unless you use a battery powered usb charger.
https://www.compuclevergear.com/products/iphone-7-lightning....
Here's a cheaper version on Amazon: http://a.co/d/fwvhCGu
iPhone 7 Lightning Splitter, Dual lightning adapter, Dual Lightning Audio + Charge Adaptor, dual lightning cable , Dual Lightning Splitter with Data Sync for iPhone 7 / 7 Plus (iOS 10.3 or Later)
4_7c363a97-8a6b-44ca-b00c-f8f0965b2a82_1024x1024.jpg?v=1498614572
