Sign in to follow this
Followers
0
SPIDER VALVE HUMMING AFTER TURNING AMP FROM STAND BY
By
spearus, in Spider Valve
BillBee 393
When is the last time the tubes were changed?
spearus 0
bought the amp last feb-used. never had them changed...my first tube amp
BillBee 393
Yeah it "might" be time as they don't last too long under steady use.
That is my best guess.
Way back when I got my first real tube amp it started sounding like a motor boat (sputtering, spitting) yep - tubes. 1-2 years was all I got out of them. But they do sound damn good!
spearus 0
thanks a bunch appreciate it :)
Did you find a solution to your problem. I'm having similar issue with my amp.
Followers
0
Hi everyone need some help.
When i turn my amp on everything is fine..but after i let it warm up for a min and switch it from stand by to start playing i get this hum...
Sometimes it gets a little louder when playing and ill get a pop or crackle..then after a few minutes it will go away.
Ill switch it to standby and it goes away......is it my cabinet?
Everyday i go to play it will hum when i switch it from standby????
Help
