Amplifi as USB interface
Boromedic
Hi can any Amplifi owners help please?
I know it's possible to record using the core amps and fx in the Amplifi, however my question is would it be possible to plug another modeller into the front end of the Amplifi and have it record my guitar tone from that without any additional fx or modelling from the Amplifi.
So basically can I turn all the modelling off and still record??!! Or are there better options for this?
Thanks in advance,
Alan
It is possible to turn off all modeling in Amplifi. Turning off the effects modeling is pretty straightforward, you simply turn them off. To get no amp modeling, select your amp block, select the clean category of amps, and the first option is no amp. You will just have audio signal you input without any modeling. Depending on what you are recording this could be a solution.
