Global volume
dannepop
Is it possible to get a global volume pedal without making an object in the chain?
When having an object in the chain it always saves the current volume setting.
Having problem with this sometimes!
Perhaps I get used to it!
D
This situation is easily remedied. If you have the floor Helix you can use a volume block in any preset and set the Global Settings --> EXP Pedals --> 'EXP 2 Pedal Position' parameter to 'Global'. This will allow the Helix's internal expression pedal to correspond to the current position of your expression pedal in any preset rather than a saved preset value for the volume block.
External volume pedal options would include using one in a send/return or in-line before or after the Helix. Ultimately I think what you really want though is just to change the setting I referenced to 'Global'. This should configure things the way you want them.
