KennyFenderstrat 0 Posted December 27, 2016 How long does the battery last between charges on the Spider V 120? Will it last for a 4 hr. gig? Quote Share this post Link to post Share on other sites
deadlocked 27 Posted December 28, 2016 Are you talking about the battery in the G10T? If so, I read somewhere that on a full charge, you can get at least 8 hrs (if new, batteries tend to lose charge capacity with age, so YMMV). Assuming a full charge, you should have more than enough to get through a 4hr gig, assuming the G10T is in good shape. Found it... http://line6.com/support/page/kb/_/live-sound/relay-digital-wireless/relay-g10-faq-r808 The relevant part: Q: How long does it take to charge the battery?A: On average, a transmitter with its battery in a discharged state has given the following results when tested: 15 minutes of charging gives at least 1 hour of run time 30 minutes of charging gives at least 2½ hours of run time 3½ hours of charging (full charge) gives at least 8 hours of run time Quote Share this post Link to post Share on other sites
guitardad123 21 Posted December 28, 2016 Mine ran 7 hrs before it died. It will last a gig no problem. Mine gets plugged in when I start staging my gear which takes an hour. We get an hr or more after we set up to chill and relax. 2 hrs is plenty of time to charge the g10t Quote Share this post Link to post Share on other sites
