CAN THE AMP MODELS BE TURNED OFF & USE FH FOR THE EFFECTS ONLY?
KennyFenderstrat
  • 2 weeks later...
Hi if I use the switch to select the Kind of output on the rear and plug into an ampli will I get sound with only effects or willI also have amp modulation?
Hi beppepelagio, the switches on the back of the Firehawk FX do not control any of the modeling. They are simply for switching signal levels when sending the audio signal out to a sound source. If you want to turn off all amp modeling go to the "clean amp" category and select "no amp", this will give you just effects.
Choose the Line Level setting if your using headphones with the FH or going into a FRFR - Full Range Flat Response powered speaker. If  you are going into the front of an amp or using the EFX loop of the amp, choose the AMP Setting
