Matyrker Posted December 29, 2016 Share Posted December 29, 2016 I'm sure this has been asked quite a bit before…I know that can import HD patches to HD X models but can you go the other way? I have a few HD X patches that I would like to utilize on my HD Pro. Thanks! M Quote Link to comment Share on other sites More sharing options...
BillBee Posted December 29, 2016 Share Posted December 29, 2016 Yes, depending on how much DSP the X uses. Quote Link to comment Share on other sites More sharing options...
Matyrker Posted December 29, 2016 Author Share Posted December 29, 2016 Yes, depending on how much DSP the X uses. What would be the correct way to convert the files? Quote Link to comment Share on other sites More sharing options...
silverhead Posted December 29, 2016 Share Posted December 29, 2016 What would be the correct way to convert the files? This file converter is probably the best method. Thanks to community member jzab. https://www.jzab.de/content/pod-hd Quote Link to comment Share on other sites More sharing options...
BillBee Posted December 29, 2016 Share Posted December 29, 2016 Yep, just watch pedal assignments too so double check everything if its a back-up rig. No sense demonstrating that "this one goes to 11" :D Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted December 29, 2016 Share Posted December 29, 2016 What would be the correct way to convert the files? You don't even need to convert the files. If something uses too much DSP, you can open the file in offline mode to remove one of the blocks. For me, it is usually a volume pedal. But it could be any number of things depending on your own personal likes. Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted December 29, 2016 Share Posted December 29, 2016 Probably, the reason you asked about converting is because you are using the File/Open menu option. In that case, EDIT will not find the the other unit's files. BUT, if you simply click-and-drag the files into EDIT, they will open just fine. Quote Link to comment Share on other sites More sharing options...
Matyrker Posted December 30, 2016 Author Share Posted December 30, 2016 You guys all helps tremendously. Thank you! Quote Link to comment Share on other sites More sharing options...
