Smashcraaft
Replacement nut Graph Tech Black TUSQ for JTV-59
Black TUS Q XL: BT-6543-00,  1.6" x .6" x .1", with angle slots at 5-degrees,
42.89mm x 7.99mm x5.08mm.
The one in the link has a rolling breaking angle, do not use that one.
Thump it with your finger nail, if it rings too much or has a hollow sound,
it's the wrong density. Should feel similar to Bakelite only more solid.
I don't see it on Graph Tech's current list, so as close to a BT-6543 as
you can get.
Or try to get it through our service partners at Yamaha Euro or an authorized
Line 6 service center in your area. They can email me for a part number thru
the usual tech request channels.
Just because I am not a native speaker... do I understand you right that the nut used in the JTV-59 is no longer available via the manufacturer and there is no similar replacement in stock at Graph Tech?
Where can I find you authorized service centers in Germany for further information?
Not certain about availability in your area. Check with Graph Tech and you're
local Line 6 authorized service center. They may be able to get it or point you
in the right direction to get it.
There is no Lin6 authorized guitar service center in Germany n your map. That's bad.
I will contact Graph Tech next...
There's PMS Electronics in Minden and  Beats & Bytes in Dietzenbach.
Okay, I do understand :blink:  Your filters are crap ("Show only stores with…").
If I apply a filter as stated above (guitar) there is no data. Not one filter works  <_<
Try it by yourself using "frankfurt" +200 km
A Line 6 authorized service center should be able to get parts and service for any Line 6 product
that's still being serviced.
Log a support ticket in your account or contact at Tel: +49 (0) 4101 303 0 .
Thank you but I found one at PMS.
Vielen Dank. Bitte geben Sie noch den Fehler mit den nicht funktionierenden Filtern auf der Karte an die Web-Techniker weiter. Einen schönen Abend!
Thanks for letting me practice on you what little bit of Deutsch
I still recall from middle school. :)
Einen schönen Abend to you too.
