renatonm
SOLUTION AND / OR UPDATE FOR THE NON-DESIRED VOLUME INCREASE IN THE CHORUS (AND OTHER MODULATIONS) OF THE M9
Hello friends!
I read through the photo and I suppose I mentioned the subject several times, but I could not find a definitive solution, but only alternatives, for the bad volume increase when we use the chorus and modulations of m9.
For me and the other people is a very annoying subject because with the simple fact of activating the chorus (I use the analogue chorus) the volume increases. If I decide to lower the mix to 0, the volume increase remains.
The alternative that I have thought is to create that effect bank with the slightly less volume, for which I have to use the pedal volume. This solution seems the most reasonable but not the simplest.
I would appreciate if you could give me another alternative solution or the people of Line 6 who can give an official answer on this problem and can give us an update that I think would be the only alternative.
I am waiting for your answers and help
Thank you very much!
regards!
Hi Renatonm,
Some time has passed since your post so I was wondering if you found a solution for this because I'm having the same problem. I switch a lot between FX and scenes so the difference in volume is very problematic. A solution I tried was placing a limiter or compressor at the end of the FX-chain to manage the volume peaks that some FX give. It's not the ideal solution, especially because the compressors and limiters are mono and therefore make stereo FX mono. I will be experimenting with a stereo hardware compressor/limiter, hopefully that will help.
Regards
