Recording a mic through Helix.
CBTL
I'm planning on recording a few YouTube videos using helix. Now I know that there is a mic input however the only mic I have is a little Sony one with a 3.5mm stereo jack. Will work with a converter through the aux input? Is there a way to have say the mic record on one track and my guitar on another. I'm all a bit clueless with this. I use adobe audition to record. Thanks 🙂
It should work fine as long as your mic doesn't require Helix to provide power to it.  You could go into the aux input but, if your mic is stereo, I'd recommend getting a cable that splits the left and right channels to separate mono 1/4" ends and going into one of the fx returns.
I'd run the mic on one Helix path and the guitar signal on the other.  That way you'll have no problems recording the separate tracks in Audition.
Iv been and bought a cheepish mic with xlr. Is it normal to have to boost it +40db in the global? What is the 48 phantom thing?
I don't ordinarily use a mic with my Helix so I have no idea if +40db is normal. Maybe some other folks can weigh in on the settings they use. Generally it is condenser mics that require phantom. I would look at the documentation for your mic to see if it requires phantom power and if so what voltage it requires. If you can't find any docs then try it first without.
https://en.wikipedia.org/wiki/Phantom_power
