Hd500 to Line 6 Spider 112
paulSC70
Hello,
I have an old Line 6 Spider 112 and was wondering if I can use that as the output for my hd500. Id like to bypass the spider 112 amp models and just use what the HD500 offers instead. Is that possible?
Thanks
Paul
If the Spider has an FX loop, yes. Otherwise you're stuck going from the POD into the front of the amp. In which case, you're daisy chaining two modelers together, and that tends to produce results that are somewhat less than inspiring.
As mentioned in another thread asking pretty much the same question, you can turn the amp on while holding down the tuner button and you'll bypass the preamp completely.  The down side is that you won't be able to control the volume on the Spider.
The amp has a pedal jack that can be used for a Line 6 floorboard. The jack looks like a dsl cable jack. I wonder if I can use that
NO, NO, NO....don't do that. It's a pedal jack, not a "line in". That connection powers those floorboards, and accepts commands from it, but it's not designed to accept an audio signal. You don't want to send juice to the POD. You'll damage it, and possibly the Spider as well.
I run my 500X into my Spider IV.  I bypass the Spider modeling by pressing the tap/tuner button while turning on the unit.  You have to have the 500 plugged into the amp with the master volume all the way down before turing the spider on.  The Spider has no volume control at this point.
Is this an old red faced Spider 1st Edition? The Spider i's and ii's did not have MP3/CD jacks as I recall...And I am not sure the original red spider had the power up trick either...However, if you use that trick you have to make sure the device feeding it is using Line Level....It might be that if you tried it and your HD500 was in AMP mode that the level would have been so low that you might not have heard anything if the power mode was actually working...
Thanks for the information. I've been able to get it to work with one issue. Every time I play there's like a 2 second delay. I tried different output options and I'm not using any delay effects. Any Ideas of what would cause it? I do have the red face spider 112. I hold the tap button when turning it on but haven't tried turning it on without holding it.
