Master Volume using Line 6 Link and HD500X
CraigGT
The L6 LINK Connectivity Guide for POD HD & DT Amplifiers v2.10 clearly states that,
• The MASTER VOLUME controls are not synced between POD HD or any connected DT amps. The POD HD Master Volume also has no effect on the signal fed to the DT amp. Simply use the DT amp Master Volume knob on each amp to control its volume.
Well my pod master volume is working so is that something that changed between the HD500 and X versions because the guide only refers to the HD500 or have I got something wrong?
I also thought that Mic modelling was turned off when using the link? I don't have the option of 'None' in DT Edit.
Thanks in advance
Craig
  • 2 weeks later...
