Sign in to follow this
audinsuro80
Spider V headphone socket
Hey People,
I would like to use the headphone signal for the FOH mixer but also use the speaker in the amp at the same time.
Is it possible to disable the "Speaker out, if a plug is in the headphone socket" function?
I actually use the headphone out with an DI to get the signal to the FOH mixer. but so, I have no sound on stage.
Or is it possible to get the signal out, like the DI out in the Spider V 120 and higher? I think the electronic boards in the amps will not so different...
Regards
There's usually a switch or sometimes a sensor device that disables the outputs when using headphones. To send to PA, might be easier to just mic the amp.
