Damned5 0 Posted January 24, 2017 So my dad bought me a Pod HD pro x for Christmas. I wanted to plug it into my cabinet and I found out that it was really quiet when i tried using it as an amp head. I relize that I would need a poweramp for it to properly work, but I was wondering if I could use my amp head as a substitute for a power amp. Anyone know if that's a possibility? Cheers. Quote Share this post Link to post Share on other sites
cruisinon2 2,596 Posted January 25, 2017 That head has no FX loop, so you're stuck plugging the POD straight into the front of the amp. Chaining two modelers together will not work well. You need a power amp. Quote Share this post Link to post Share on other sites
thorneven 70 Posted February 1, 2017 You can use the front of the Spider IV. Just make sure you dial up the cleanest Spider preamp settings you can so that they don't interfere with your 500X settings. Quote Share this post Link to post Share on other sites
spaceatl 1,976 Posted February 1, 2017 Your amp should have a CD/MP3 input. You can run the Headphone out or the 1/4 line outs and adapt to stereo 1/8. Quote Share this post Link to post Share on other sites
okelliheru2 3 Posted February 1, 2017 Power up the spider and hold down the tuner button. You will bypass the modeling in the spider. Plug right into the guitar-in port. (1/4 inch in) Make sure the Master volume is down on the Pod. The Spider has no volume control. Quote Share this post Link to post Share on other sites
spaceatl 1,976 Posted February 2, 2017 Power up the spider and hold down the tuner button. You will bypass the modeling in the spider. Plug right into the guitar-in port. (1/4 inch in) Make sure the Master volume is down on the Pod. The Spider has no volume control. The power amp test mode is a pretty good one...However, if the amp experiences an interruption in power it will not longer be in that mode when it comes back. Quote Share this post Link to post Share on other sites
