jordans0nly 1 Posted January 24, 2017 Would it even be worth it to buy the 1x12 or 2x12 version and run the Helix through the speaker? Just looking at a few options for FRFR to upgrade from my Behringer FS1220. Quote Share this post Link to post Share on other sites
gunpointmetal 591 Posted January 24, 2017 They are Full Range, but definitely not flat response. Also, there is no FX loop, so to bypass the front end you'd need a 3.5mm Stereo plug w/two mono 1/4" jacks at the other end to make use of the 2x12 stereo features. There's been several discussions between here and TGP about integrating the Helix with the Spider V and the consensus from L6 seems to be the two products were never intended to be used together.....even though, IMHO, adding a stereo effects loop to the 2x12 combo and the 240HC head would have probably shifted a bunch more units, since people could easily integrate it with Helix at a price point well below the $1000 bucks the FireHawk amp costs. Quote Share this post Link to post Share on other sites
jordans0nly 1 Posted January 24, 2017 Good point. Any amp worth doing this with? 9r just pick up a frfr monitor? Quote Share this post Link to post Share on other sites
zooey 265 Posted January 25, 2017 I posted a bit ago about doing something similar with a Blackstar ID:60. Been playing with that off and on since. Results are mixed,w that particular amp, but it's a nice and compact package, and the ID is nice in its own right. Quote Share this post Link to post Share on other sites
marcioguitar 1 Posted May 28, 2017 Last night I brought my Helix to a gig and in fact used the Spider V 240 as FRFR cabinet and I can tell you, amazing results!!!!!! instead of connecting in front of the amp you connect in the back of the Spider, that bypass the entire pre amp, effects, everything!!!!! The only thing that works is the volume! Use the AUX IN! The 240 version is a stereo version! from there you can send a L/R to the FOH, also you can use a splitter cable to send the signal from the Helix into a stereo 1/4"cable and send it to the Spider V. There is no way to go wrong guys, I got the same results connecting my Helix into a Line 6 FRFR monitor (L3M), exactly the same with the advantage to use the spider in small environments! Quote Share this post Link to post Share on other sites
brue58ski 661 Posted May 29, 2017 It's expensive but check this out. https://www.sweetwater.com/store/detail/Spacestation3 Quote Share this post Link to post Share on other sites
zooey 265 Posted May 29, 2017 Two new models of that on the way too, a physically lighter version with the exact same speakers, amps, and specs, and an XL version, bigger and more powerful. Quote Share this post Link to post Share on other sites
hideout 193 Posted May 30, 2017 Two new models of that on the way too, a physically lighter version with the exact same speakers, amps, and specs, and an XL version, bigger and more powerful. I had the early version. It was ok, just not very loud and deceptively heavy for its size. I never got used to its sound. Quote Share this post Link to post Share on other sites
FlyingsCool 79 Posted May 30, 2017 There's some other threads on this. Actually,... I don't own one, but apparently there is an 1/8 in stereo Aux In that bypasses the preamp, You can get a dual 1/4 to 1/8 stereo cable and connect Helix into that. People have been happy with that. Quote Share this post Link to post Share on other sites
lungho 72 Posted May 31, 2017 I've got both, the Helix and the Spider V 120. Indeed you can run your Helix through the 1/8" aux in the back, bypassing the preamp. To me, the sound is acceptable but is in no way a replacement for a good FRFR monitor. I'd like to find someone with a 240 and see if there's a difference. Quote Share this post Link to post Share on other sites
