Sign in to follow this
lotjrsula
Variax 600 stops suddenly and then turns on again.
Hi All,
I kindly need help from your experience with the old Variax 600. I purchase brand new one here in UAE but unfortunately the one I had has issue. I use this in our church and my problem is its suddenly turning off and cuts off volume and then turn on again.
I've done a reset but still the problem exist. Is this a hardware problem?
I tried also to use other cable and also the Di adaptop which powers-on the variax but still encounter the same problem. At first it is working properly and then all of a sudden it just cuts off the volume and no more sound coming out and then turns on again.
Really appreciate if you can help me with this problem and kindly please tell me what to do.
Thank you.
Cheers.
Hi All,
Thank you.
Cheers.
If you bought this new, return for a replacement, or warranty repair. I'd say it's hardware related - similar happens to me on my 600 vaxplant - it's around 10 years old now. I tune it up, ready to go for the first set, select a patch - nothing. Disconnect everything, press a few patch buttons, back into the tuner, back out to a patch, sometimes it operates just fine, others just no signal. It can be fine for a few weeks, then won't operate....
