Midi CC on Tap Tempo
ricardo_maia
I programmed a CC to be send when Tap switch is pressed. Everything works ok in Stomp mode. But when I am on snapshots mode I need to press twice the Tap switch to get a single CC message.
Did anyone ever noticed this?
Steps to reproduce:
1. Go to command centre and select the Tap switch
2. Select MIDI CC Command and set Channel, CC and Value
3. Exit Command Centre (and save preset)
4. Enter snapshots mode (if you're not in that mode)
5. Press once the tap switch  - no CC message is sent
6. Press it again - CC message will be sent
Continue to press Tap switch. A CC message is only send every other switch press.
regards,
Ricardo
  • 1 month later...
