ricardo_maia Posted February 14, 2017 Share Posted February 14, 2017 Hi, I programmed a CC to be send when Tap switch is pressed. Everything works ok in Stomp mode. But when I am on snapshots mode I need to press twice the Tap switch to get a single CC message. Did anyone ever noticed this? Steps to reproduce: 1. Go to command centre and select the Tap switch 2. Select MIDI CC Command and set Channel, CC and Value 3. Exit Command Centre (and save preset) 4. Enter snapshots mode (if you're not in that mode) 5. Press once the tap switch - no CC message is sent 6. Press it again - CC message will be sent Continue to press Tap switch. A CC message is only send every other switch press. regards, Ricardo Quote Link to comment Share on other sites More sharing options...
ricardo_maia Posted March 28, 2017 Author Share Posted March 28, 2017 Hi, Did anyone also noticed this? regards, Ricardo Quote Link to comment Share on other sites More sharing options...
