jyanes
amps and cabs that typically are paired together
Does anyone know where i could see a list of AMP models in the Helix and what Cabs they would typically be paired with?   Including mic combinations?
Looking for a starting point guide.
If you insert the combined Amp/Cab block, the amp and cab that are paired together will show you what the default pairing is.
Don't get stuck on the idea that you have to use the default combinations though....if it sounds good, it is good. Doesn't much matter if the pairing "makes sense".
This, so much this.
I have used things like piano presets in EZMix as FX for a guitar signal chain. Point is there is no wrong way as long as it sounds good.
watch-out-we-got-a-badass-over-here-meme
Sorry, couldn't resist... :D
stolen meme
Aren't they all?
I actually very rarely use the "correct" cab with an amp. The biggest exception being the Dr. Z.
I agree with the rest. I'm using the Litigator pre amp with a Vox AC 30 IR cab and a Jackson amp works IR cab and it sounds amazing. Do what sounds good to you.
