Variax 300 acoustic sounds rubbish?
Nathcloud9
As Charlie_Watt mentioned above, modeled acoustic sounds require the same type of sound reproduction required with a normal acoustic instrument. Plugging an acoustic guitar into a standard combo amp typically does not produce desired results, same thing with the modeled sounds. A PA, acoustic amp, or some sort of FRFR speaker is your best bet.
