How do I back up POD XT LIVE settings to a PC ?
I have a POD XT Live which I use for gigs and want to be able to easily change the positions of the different settings (to match the set list order which changes). I understand from the manual that I can backup to a PC, but when I connect with USB, PC does not see the device. Is there some special software I need on the PC ?
Mike
You need to download and install the Line 6 Edit program. You will find it in the Downloads area of this website (under the Support tab above).
I have windows 10 which line 6 Edit download doesnt appear to be available for, I downloaded windows 7 version, but its sticks at prompt select from a device listed below with no devices listed.
  • 2 weeks later...
