AVF925 Posted March 14, 2017 Share Posted March 14, 2017 Gents, Is is possible to assign a Wah to a foot switch and when it's activated, then an expression pedal controls it? I have "2" Morley Expression Pedals - neither has a "SWITCH" in them - and I'd like to be able to not buy another pedal . . . Suggestions - thoughts? Thanks Quote Link to comment Share on other sites More sharing options...
phil_m Posted March 14, 2017 Share Posted March 14, 2017 I'm not exactly sure what you're asking... But it sounds like you're wanting to use one of these expression pedals to control wah. The auto-engage feature was added with the 2.10 update, so you actually don't need to assign the wah to a footswitch to turn the block on and off. You can select EXP1, 2 or 3 for Bypass Assign and then assign that same EXP as a controller for the wah, and it will turn on once you move the pedal past a certain point (whatever percentage you select). Quote Link to comment Share on other sites More sharing options...
AVF925 Posted March 14, 2017 Author Share Posted March 14, 2017 Cool - I'll set it up - thank you Quote Link to comment Share on other sites More sharing options...
jbuhajla Posted March 15, 2017 Share Posted March 15, 2017 Gents, Is is possible to assign a Wah to a foot switch and when it's activated, then an expression pedal controls it? I have "2" Morley Expression Pedals - neither has a "SWITCH" in them - and I'd like to be able to not buy another pedal . . . Suggestions - thoughts? Thanks Connect your two external expression pedals to the two external expression pedal ports on the back of the unit (EXP2, EXP3). Then you can use those for anything, including wah. Just assign the wah block to a foot switch to turn on/off, and use the expression for control. Quote Link to comment Share on other sites More sharing options...
