amschaaf
MP3 playback on Spider V 60 watt?
There is an 1/8" aux in on the rear of the amp.  You can connect whatever audio device you want and play music through it.  The aux in bypasses the amp modeling stuff so you can play with high gain amps without affecting your backing track.
You can also use the USB to stream audio to the amp. If you have a tablet connected you can control the amp with Spider Remote and play music.
Guest Bri
Is there a way to adjust the volume of the MP3 seperate from the guitar volume so that you can better hear the track to play along with?
Guest Bri
I use the volume controls on the audio device/mp3 player and the master knob on the amp (which controls, both, the overall level of the amp and any connected audio device) to adjust the volume until I reach the desired level.  Then I adjust the amp volume, within whatever specific model I happen to be using, until both the amp and the audio track are mixed together.
There might be other ways of doing this, but this is what works for me.
